Biggest Tire Size
Old Sep 24, 2008 | 05:27 AM
Riprock's Avatar
Default Biggest Tire Size
I have a 2007 rubi... situation is I have a 2.5 teraflex econo lift with the standard rubicon rims and tires. I have the money now for tires only...so what is the biggest and best size tire I can fit on the standard rubicon rims?
Old Sep 24, 2008 | 05:42 AM
HappyCurmudgeon's Avatar
Eternal ***erator
On stock wheels without spacers, your going to be limited on width.
I have 33x12.5-17's on my stockers with a 2" BB. Height wise they would have been fine & I may even have gotten away with 35's as far as height, but the width would have caused rubbage without the spacers.
Lots of people with that combo you have, i am sure someone else can be more precise for you.
Old Sep 24, 2008 | 05:46 AM
nclehmann's Avatar
You'll need wheel spacers if you want to go bigger using the stock Rubicon wheels. A set of 4 Spidertrax 1.5" aluminum wheel spacers will run you about $200. A set of 5 steelies with less backspacing than stock wheels will run you about $300. Either way, you need to push out those wheels so you don't rub on your suspension components. If you do that, you can run 35s with a 2.5" lift and maybe get some rubbing on your fenders at full turn while fully stuffed - no big deal.
Hope this helps.
Old Sep 24, 2008 | 06:18 AM
Riprock's Avatar
Thanks for the great advice....
Old Sep 24, 2008 | 05:51 PM
Frog Rubicon's Avatar
Hope this helps.
If you off-road, don't buy the wheel spacers; buy the steelies, and you will save your wheel bearings
Old Sep 24, 2008 | 07:06 PM
nclehmann's Avatar
I agree!
(I think black steelies look better, too! )
Old Sep 24, 2008 | 08:04 PM
Riprock's Avatar
What would be the correct size on the black steelies? Getting really fired up to do this now and learning a lot in the process!. Thanks again to everyone who has responded so far... it's been a great help
Old Sep 24, 2008 | 08:11 PM
joe002's Avatar
The difference in the stock vs. aftermarket backspacing is what causes additional stress on wheel bearings. If your stock wheels with good spacers (hub-centric on both sides) have the exact same backspacing as an aftermarket wheel, then the additional stress on the wheel bearing will be the same.
Old Sep 24, 2008 | 09:17 PM
Beta-pg's Avatar
Yeah.... What joe said! I've got spidertrax 1.5" on my rig and I play pretty hard 3 or 4 weekends outta the month. They're all fine. Just had them checked about a week ago.
Either way, you'll need to decrease the amount of backspacing. Either via aftermarket wheel or a QUALITY spacer like the ones offered by TF or Spidertrax. Happy Wheelin'!
Old Sep 24, 2008 | 09:52 PM
Rubimon's Avatar
You can get new aluminum alloy wheels for a little more than steelies I think, and they come with center caps and lug nuts usually. By the time you are done it is not that much more for a lighter/nicer wheel. It has been a little while since I priced this stuff though.
