Anyone have this wheel/tire set up
Old Mar 30, 2007 | 03:43 PM
JeepGuy's Avatar
Default Anyone have this wheel/tire set up
Wondering if this would work on a Rubicon w/o a lift...
Pro comp rims, 17X8, 5x5 bolt pattern, 0mm offset, w/ 4.5" backspacing
Mickey Thompson Baja MTZ radials LT265/70R17 which i guess equals 32x10.50R17LT.
Just looking for something that will work without rubbing issues if anyone is able to provide some insight, or better sizes that would work without rubbing issues.
Thanks
Old Mar 30, 2007 | 09:00 PM
Gasser's Avatar
Gosh, that is almost exactly the same size at my Rubi stock tires on a wider wheel and spaced out about 1.5 inches. It should not rub at all I would think. Should look great as well.
Old Mar 31, 2007 | 11:26 AM
JeepGuy's Avatar
Thanks for the info!
