garvin mount can+Bushman steel rack
Old Sep 29, 2008 | 09:46 AM
reaper's Avatar
Default garvin mount can+Bushman steel rack
hi,i would like to know if the garvin gerry can mount fitt on the Bushman steel rack??
http://www.quadratec.com/products/12044_900_07.htm
http://www.quadratec.com/products/12138_302_07.htm
thanks in advance
Old Sep 29, 2008 | 01:01 PM
reaper's Avatar
so anyone have idea??
Old Sep 29, 2008 | 07:01 PM
silver rubicon's Avatar
do you have the can holders already? if not, i have two that are in new condition that i am willing to sell. in any case, if you have basic welding skills, you can buy the metal needed to make new brackets to fit the new rack--shouldn't be a problem.
Old Sep 30, 2008 | 05:11 AM
Littlejon's Avatar
Looking at the set up it looks like the cans would mount to the side of the rack, so this would not work since the rack fits on the roof, unless you layed the cans flat on their side, but then they are more likely to leak Wouldn't just setting the cans on top of the rack, and strapping them in securely work?
Old Sep 30, 2008 | 06:12 AM
reaper's Avatar
i wanna do this with a bushman rack:
http://img515.imageshack.us/my.php?i...rvingasqx1.jpg
it seen exactly the same mount...will fitt??
SILVER RUBICON send me a picture of your can mount via PM please!!
Old Sep 30, 2008 | 09:15 AM
Littlejon's Avatar
I don't think the garvin mounts will work because in the picture the garvin clamps to the bar at the middle of the mount. I don't think it will work unless you can move the clamps down, otherwise they will be like 6" above the edge of the basket. Also those have support under the can, and with a roof rack you would not need this. I know that Gobi Racks has a set up like what you are looking for.
Old Sep 30, 2008 | 06:20 PM
oh, i see what you are doing; yes, the garvins will do what you want, and it looks like no fabrication will be necessary. you will only need to remove the two bars that mount to the garvin tire rack (they are secured with two bolts each) then bolt the bottom of the can holder to the bushman rack. it will be easier than i thought. i will pm you photos of the can holders.....
