1.25" spacers
Old Oct 1, 2008 | 05:08 PM
sqareyz's Avatar
Default 1.25" spacers
i just picked up sum 1.25" spacers for my heep.
problem is, the ad said 1.5" , but when i got home they turned out to be 1.25"
stupid me, ya i shoulda mearured when i picked 'em up, but................
my question is will i run into MAJOR issues when i upgrade to the planned 35x12.5x17 tires, i don't see .25" making a big deal difference, but you never know?
Old Oct 1, 2008 | 05:21 PM
wayoflife's Avatar
JK-Forum Founder
if you keep these, you will need to grind down your wheel studs as they will prevent you from mounting your wheels flush.
Old Oct 1, 2008 | 10:48 PM
sqareyz's Avatar
already mounted them, there were no issues with them. the studs were below the spacer.
i don't see how the studs would be a problem. there is a void/space between the mounting holes on the back-side of the rim. the protruding stud would sit in that space. would it not?
i'm just curious about the tires rubbing when i upgrade.
