drop pitman?
Old Oct 2, 2008 | 12:40 PM
Biggerjeep's Avatar
Default drop pitman?
Is a drop pitman arm the way to eliminate most of my bump steer, or do i need some sort of custom steering link??
Old Oct 2, 2008 | 12:43 PM
wayoflife's Avatar
JK-Forum Founder
if you are lifted 4" or more, a dropped pitman arm in conjunction to a track bar drop bracket will help eliminate bumpsteer.
Old Oct 2, 2008 | 01:05 PM
Biggerjeep's Avatar
How much of drop can ya go with the pitman?
Old Oct 2, 2008 | 01:08 PM
wayoflife's Avatar
JK-Forum Founder
sorry but i'm not sure i understand the question. so far as i know, there is only one dropped pitman arm available for the JK and pretty much every lift kit manufacturer is using the same one.
Old Oct 2, 2008 | 01:20 PM
Biggerjeep's Avatar
I have a 4 in LA Terraflex kit, so it should have the drop pitman.
But im still dealing with a lot of bump steer.
Old Oct 2, 2008 | 01:23 PM
wayoflife's Avatar
JK-Forum Founder
so far as i know, the TF 4" long arm kit does not come with a dropped pitman arm or front track bar drop bracket. without it, you will have a lot of bump steer.
Old Oct 2, 2008 | 01:28 PM
Biggerjeep's Avatar
Thanks , Ill look into this.
Old Oct 2, 2008 | 02:54 PM
WV99XJ's Avatar
I have a pitman arm for sale if you are interested.
Old Oct 2, 2008 | 03:44 PM
jpp's Avatar
jpp
Default Another possibility
Not sure if any vendors here have one, but AEV has a kit that flips the draglink. This may be another solution for you. One that may put a little less stress on your steering box.
