Anyone running 255/85R16 tires?
I gotta say, I'm tempted... I'm on 285s now, so this would be a slightly skinnier and taller tire. My current wheels are 8" wide though, which is a little wider than the recommended 7"....
js.
js.
The two tires are virtually the same height. the 255 is 33.1" and the 275 is 32.8". That's only .3" of an inch difference. You can make that up in air pressure. Kinda moot point to go to the 255. Unless you just like a skinny tire.
Check these links out for 255/85R16's!!!
https://www.jk-forum.com/forums/jk-show-tell-33/uk-jk-mods-so-far-23997/
https://www.jk-forum.com/forums/jk-show-tell-33/lets-see-them-255-85r16s-lifted-not-30651/
js.
http://www.4wd.com/productdetails.as...5&partID=41760
This is what I plan on going with someday
