Please suggest tires for me to go with 18 x 9.5
Old Oct 7, 2008 | 08:30 AM
xxx9000xxxx's Avatar
Default Please suggest tires for me to go with 18 x 9.5
Hi, I have picked the following wheel for my JK 2dr...
American Racing ATX Series (Series 3981) with Teflon (Black color)
Backspacing: 4 1/2
What tires would you recommend if I use it 95% on highway/rormal road?
They must be no more than 33" in height, and align with the flares. Will a 285/65/R18 ok?
Thanks.
Old Oct 7, 2008 | 08:54 AM
That sounds like a pretty big and wide rim. To look good I think you would have to have at least a 37" tire.
Old Oct 7, 2008 | 08:58 AM
Originally Posted by redx08
The bfg ko's are good tire for alot of highway use and are agressive enough for the occasional wheeling. 285/65/18 will fit good.
Thanks redx08.
So it should stay under or equal to 33" in height?
Also I am not planning to do body/space lift, do you think it's ok?
Old Oct 7, 2008 | 09:02 AM
Wow, you meant it's too wide? but it should just align with the stock flare?
I must get the lower profile tires since I am driving mostly urban area.
Old Oct 7, 2008 | 05:42 PM
greenjeep's Avatar
33s will fit nicely even if you dont change the stock ride height. Go with any tire on the bfg line. Rubber is harder and will wear much slower with that much road driving
Old Oct 8, 2008 | 06:11 AM
Thanks redx08 and greenjeep, great advice!
