Before and After with 2.5" and 35's
Before the lift and tires sitting stock.
After a new Skyjacker 2.5" suspension lift and 35" tires. Still sits a little low in the front until tomorrow when I get a 3/4" bump up with a sping spacer.
Looks good. What are ya doing for the rock rails? I noticed you removed the stock ones?
Have you flexed it yet to see if it rubs? I just put spacers with my stock wheels and it looks much better but can't decide if I want to lift it a little and go with 33s or 35s.
Your pictures help me decide
I see you have a diesel pusher Motorhome as well. Looks cool. I like the look of your setup.
What is it you did not like about the rock rails? Even though I may not ever climb rocks, I like the way it hides the pinch wealds under the rig.
Are you planning to tow your jeep behind your motorcoach?
I think your jeep looks great and I love the wheels.
Jeff
Edit: Sorry but on closer inspection I can see your side steps you installed. Hard to see on my computer. Now I know why you took off the rock rails.
Jeff
Jeff
Jeff
I have the Jeep already set up for towing behind our Diesel pusher and it tows great. However....I have not towed it after lifting it up and am concerned about the tow angle for the tow bar. It flexes and pivots up and down, so it should be ok...
Here is a picture of the Jeep with the additional 3/4" spacer installed which leveled it out a lot better now...
