JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
which psi for 33 inch tires
Old Oct 24, 2008 | 04:39 AM
ksaket11's Avatar
Default which psi for 33 inch tires
what is recomended psi for 33 inch tires on normal roads?
Old Oct 24, 2008 | 04:42 AM
db1's Avatar
db1
I've been running about 32lbs, but now that it has been getting cold, the TPMS keeps going off. I just bumped it up to 37lbs to see if that would stop the ding.
Old Oct 24, 2008 | 05:17 AM
Denny2565's Avatar
The off-road shop that put on my wheels and tires put 40 psi in my 33" tires. After reading several posts on the forum, I dropped down to 32. But dropping the psi also dropped about 1.5 miles off my mpg. Acceleration also seemed a little sluggish with lower pressure. I went back to 40 psi and have kept it there. Some people may say the ride is rougher with higher pressure, but I couldn't tell any difference.
Old Oct 24, 2008 | 09:43 AM
tibbar's Avatar
I am running them at 40 psi and so far nice ride.
Old Oct 25, 2008 | 07:14 AM
n6on's Avatar
35 onroad and 17 offroad wors well for me.
Old Oct 25, 2008 | 07:35 AM
vwJarhead's Avatar
x2 on that.
Old Oct 25, 2008 | 07:56 AM
ShadedOutDoors's Avatar
35 street 18 dirt
My TPMS went off once it started getting cold out I had 33 PSI and checked it went down to 30 cause of the temp drop.
Old Oct 25, 2008 | 08:26 AM
lijeepguy's Avatar
ok heres the deal if you keep your 33s at 40lbs you will wear the inside tread on your tires quicker than the outsu=ide treads , so less milage out of your tires, but you will get more mpg , becuase theres less rolling resistance, i run my 33s at about 33lbs in front and 35 in the rear on the street , off road i go to between 16lbs and 18 lbs , i get a nice belly in the tire and havent broken a bead , i hope this helps you out
Old Oct 26, 2008 | 08:03 PM
greenryde's Avatar
x2 on that
Old Oct 27, 2008 | 01:59 AM
SLeepY_BoY's Avatar
i put 35psi onroad, and 4-5psi offroad.
