2.5 BB with flat fender flares?
Old Oct 24, 2008 | 09:30 AM
stlfan06's Avatar
Question 2.5 BB with flat fender flares?
Does anyone know what size tires I could run with this setup???
Old Oct 24, 2008 | 09:35 AM
stlfan06's Avatar
also what gears would be necessary?
Old Oct 24, 2008 | 09:44 AM
noot's Avatar
You could run 35" tires with no rubbing.
What gears depends on a number of things: What your diff gearing is (either 3.21, 3.73, or 4.10) and whether you've got an auto or a manual tranny.
Either way, many people run 35's without re-gearing. Whether it's optimal is up to you.
Old Oct 24, 2008 | 09:48 AM
freshjk's Avatar
If you choose the 2.5bb you will be able to run 35's comfortable! I am running a rubicon express 2.5bb with 33's and have plenty of room for 35's. As far as gearing I would get 4.88's if you are planning to run 35's. However, if you think you will go with a bigger lift in the future and will run anything bigger than 35's I would get 5.13's. Hope this helped!!
Old Oct 24, 2008 | 10:56 AM
stlfan06's Avatar
Well i'm all stock as of now, running 3.21, with a manual tranny. If I had stock 4.10 gears I probably wouldn't worry, but thats sounds like pushing it quite a bit.
Gas mileage isn't my biggest concern, but has anyone noticed how much it changes when you bump it up to 4.88 or 5.13?
Old Oct 24, 2008 | 11:02 AM
SASQUATCH's Avatar
35s easy and 37s no problem. I'm considering 38s but have trimmed my Rubi rails already and have right at 3" of lift with my 2.5" BB.
