TC linkage problem and some poser pics
Old Oct 26, 2008 | 12:49 PM
jkexpeditions's Avatar
Default TC linkage problem and some poser pics
Took the new Heep out this weekend after Jeeptoberfest. The little JK performed excellent except for one little flaw, the transfer case linkage broke on me. Of course this happened while shifting the case so you know what gear it was in when it let loose heh heh neutral. Fixed with a tie wrap. The problem was the black plastic arm that attaches to the case's shifter bracket (on the case). It looks like there used be a pivot ball in the end of the plastic piece /shrug. Still not sure if it's Jeep error or if it took a hit on the trail or something in one of the mud holes. Off to the local Jeep parts dept Monday. Anyhow, here's some poser pics from the ride, wimpy I know but it's all we get around here in Florida.
Old Oct 26, 2008 | 04:08 PM
style_front's Avatar
Looks good man, cool piktars.
Old Oct 26, 2008 | 04:28 PM
ronjenx's Avatar
Please post a pic of the part that broke. The new one will do. Also, list the part number. I would like to carry a spare. This seems to be a common weak point.
Old Oct 26, 2008 | 04:58 PM
d0wnShifT's Avatar
Dude, that's an impressive amount of flex you got there!
Old Oct 26, 2008 | 05:11 PM
micja's Avatar
Cudos on the flex.
Old Oct 27, 2008 | 08:05 PM
TINMAN080's Avatar
From what I've experienced myself, if you don't have a slight bit of ''roll'' when shifting the transfer case, the cable mechanism can break fairly easily. The ''at rest'' transfer case shift effort exceeds the design limits of the cable ball attachment mechanism.... Just my thought....
Old Oct 27, 2008 | 08:25 PM
ronjenx's Avatar
That is exactly true, also applicable if the drivetrain is bound up on a hard, dry surface.
Old Oct 28, 2008 | 05:21 PM
The dealer is fixing it under warranty as it appears to be a common problem. Not the first one they had fixed. Here's the pic you asked for. No cudos necessary for my superior tiewrapping abilities
While at the dealer I asked about a recalabration on my computer for the 29 inch to 32 inch tires. They said that they charge $90 because there are a bunch of calculations to do. Two different dealers told me this. Is this true? I recal'd my dodge and it was a simple jack in, tell it the new size...less than a minute.
Old Oct 28, 2008 | 06:08 PM
2drREDROCK's Avatar
Awesome pics
Old Oct 28, 2008 | 08:19 PM
ronjenx's Avatar
Thanks for the picture. It definitely looks like a weak point. Is it plastic?
Excellent field repair!
