Does this Xfer case armor need to be fixed?
Old Oct 27, 2008 | 09:26 PM
kurtfriedrich's Avatar
Default Does this Xfer case armor need to be fixed?
I am wondering if I need to un-bend or replace the Xfer case armor. its bent up quite a bit on the pass side. I am thinking maybe it is putting bad pressure on the Xfer case? Or putting strain on the driveline? Or is this just normal wear and tear? (ignore the 2 dents in the gas tank shield, there ok)
Kurt
Old Oct 27, 2008 | 09:38 PM
Piginajeep's Avatar
Think of it as gained clearance.
I think you need to start looking at after market skids. The metal will never be strong like it was before, the gas tank skids are a joke.
Old Oct 27, 2008 | 09:44 PM
Piginajeep's Avatar
Originally Posted by SONIC
Just dont drop the gas tank on yourself if you take the skid off!!!
it STUPIDLY IMO holds up the tank!
thats basically how all jeeps are made. Just put a floor jack under it
Old Oct 27, 2008 | 11:24 PM
Choppus's Avatar
Well that's a good thing to know. Make sure you have a quarter tank or less before you try to install a new gas tank skid
