Problem after changing to SOLID diff
I changed out my front diff cover to a SOLID cover tonight (finally! - after waiting for a week for Autozone to restock 75w90 fluid). After getting 'er on there and filled to the specified 1.35qts, when I throw it into 4wd it feels like I have a flat tire or something when I turn. the entire jeep kinda lags. Is this because it doesnt have enough fluid? When I put it into 2wd and its using just the rear (which is still stock because I broke a bolt from the front kit), it works fine.
Did you try turning in 4WD B4 changing the cover? The JK has a part time system (no central diff) so it's normal to feel the steering weird when turning on dry pavement. Actually, you should not run 4WD on dry panement.
Yeah, I've taken it off road a time or two.
Anywho, that is a good point about dry pavement because it was indeed dry pavement. I hadn't considered that - but it almost felt like it was locked or something. Maybe I just need to take it off road and test it
For my sanity, as long as I don't hear any grinding or anything out of the ordinary it shouldn't be a fluid issue, right?
