Change to 4.10 dealer won't flash
Get a Procomp Accu Pro OBII port programmer. It is super simple to use and will allow YOU to adjust tire size and or gear ratio. It will also automatically adjust your shift points if you have an auto
As long as your vehicle knows how fast it is going isn't that the main thing with the shift points?
The computer would be getting an accurate speed signal, and an accurate RPM since it pulls it from the engine. I think that all JK's you buy stock are just flashed for tires, and gear ration has nothing to do with it.
This was discussed awhile back in a thread long-lost to the bit bin. The conclusion was if you want an accurate speedo and related items (odometer, trip computer, etc), you need to program in the gear ratio. I can assure you I had that option when I uploaded the Hypertech firmware into my JK.
As for the Hypertech storing the serial number: I've never tried to reprogram another JK, so I don't have personal experience with that. But, I've read that some of the initial programmers could be used on multiple vehicles, but not the Hypertechs produced later.
Based on this understanding of where the vehicle speed signal originates, I believe axle gear ratio is every bit as important as tire size in determining proper automatic transmission operation.
