LED lights!
put some LED lights in the interior.. (tapped off air conditioning from yellow and black wires..ran underneath cupholders and below sway bar/axle lock etc controls)
also put some on the license plate tags.. foot lights.. and overhead light
the overhead light i got from a local electronics store.. most of them will have an LED thats connects right in.. in was a little loose though so i just tightened it with a pair of pliers..
and the license plate like i got from ebay.. i forget what kind of light it is off the top of my head but its in the manual.. they were pretty cheap.. the light wouldnt fit in the little housing that the light goes in so i had to grind it a little bit with a dremel but it fit just fine and hooked in right.
So how do you have them wired in? care to do a write up on this?
ive seen a few of these setups now and i want to add some LEDs to my foot wells both front and rear and on the dash.
looks real good
looks real good
Looks great. You hit all the "high" (or "dark") spots. I've seen a couple others in write-ups or electronics, but usually only for one of the spots. Details on each all in one spot would be great. I just have to get over my irrational fear of cutting wires...
no prob.. ill prolly take apart the dash tomorrow and take some pictures to show u guys what i did.. i was real afraid to cut wires too but its superrrr easy.. looks great too.. makes me wanna install some more LEDs!!
ill def try to do a write up tomorrow or at least take some pictures and whatnot..
