4 inch tera flex with 38's ???
Old Nov 2, 2008 | 03:02 PM
TYLERSBLUEJK's Avatar
Default 4 inch tera flex with 38's ???
Hey everyone this is my first post, I just bought a 2007 jk on 35's it has a 4 inch tera flex lift. I want to run 38.5x15x16 bogger's.
What all do i need to accomplish this. I am going to order a set of river raider tube fenders and a short front and rear bumper.
i will mostly mud with this thing because i dont know of any place's to climb in florida.
please help me out guys all oppinions are great. Thanks.
Old Nov 2, 2008 | 03:06 PM
racer83l's Avatar
my opinnion, the tires will fit. You will need to trim the pinch seam in front of the rear tire. and you will want to think about upgrading the axles, and gearing if that wasnt upgraded already
Old Nov 2, 2008 | 03:08 PM
O yes sorry also it is a 2door hard top if that matter's.
and my only other concern is will the tire rub the frame or body..??
O yes i will also probibly just do lockers and gearing i was thinking 5.38's
Old Nov 2, 2008 | 03:28 PM
Lo2aY's Avatar
I have their 4" LA and I'm running 37" tires on mine
At full flex my Tires rub bad on the rear flares and not that bad on the front.
I guess I would need a set of flares
Old Nov 2, 2008 | 03:29 PM
Lo2aY's Avatar
My tires are 13.50 wide
They rub on the frame on the front!
did I mention that I did adjust the rear axle (moved back) so that I don't have to trim anything
Old Nov 2, 2008 | 03:37 PM
wiredawg_mg's Avatar
You may also need a stubby bumber. I was rubbing on my bumper when going down a steep grade while stuffing the tires and I am on 35's and a Tera 4". Made an awful noise.
Old Nov 2, 2008 | 05:16 PM
dlincoln91's Avatar
Make it easier and run 37 boggers with tube finders then you will have some room to move and still look big
Old Nov 3, 2008 | 09:49 AM
Thanks guys for the help.
I will probibly run 37x13x16 boggers.
Old Nov 3, 2008 | 10:19 AM
RedrockX's Avatar
look up "trimmed fenders"...
they look BETTER than any aftermarket fenders, it doesnt cost much...
and will give lots of extra room.
Old Nov 3, 2008 | 02:04 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
x2 on what Redrock said!
Have the driveshafts been upgraded?
