Full traction premium lif
Old Apr 7, 2007 | 04:18 PM
Jangle's Avatar
Default Full traction premium lif
Well I installed the lift today, I have a few questions for you all:
1. After you adjust the himes joint on the adj track bar to the corect measurements, how do you move the axle over so you can bolt up the heims joint to the axle?
2. What is the best postion to place the grease fittings on the front lower control arms, right now mine are facing anterioly (towards the front bumper of the vehicle) so I think I goooobered them up any help would be great.
Other than these two issues, I have no problems w/ the kit, installation was pretty straight foward (except in my opinion the full traction instuctions are rancid and should be replaced w/ color photos)
I would have never finished the setup if it wasn't for the write up on this website and all the great advice from everyone, THANK YOU ALLL !!!!
- ANGEL
Old Apr 7, 2007 | 07:44 PM
GOCACHN's Avatar
- ANGEL
1)Have someone turn the steering wheel until the holes line up.
2) Mine seemed to work the best facing the middle of the arm but a little off center, so you can get the greasegun on them when they are under weight and up in the mounting brackets
Old Apr 7, 2007 | 07:50 PM
rubiman's Avatar
Is it leveled?
