I want to do a spacer lift help?
Where can I find the daystar 1.75 spacers or anything equivilant to this lift. I plan on up grading to 33's and keeping the stock springs and shocks I just want a spacer lift for looks and to fit the 33's. Any help or direction will be appreciated so I can order these spacers.
http://www.4wd.com/productdetails.aspx?pid=KJ09137BK
There ya go....I was going to buy this until I found a good deal on a FT Spacer Lift from a JK forum member. Now sending the spacers out to be machined so 1" in the rear and 1 3/4" in the front to level the Jeep out.
From what I read, Daystar makes the ProComp kit which I just bought off eBay. It also is cheaper.
http://cgi.ebay.com/ebaymotors/ws/eB...m=130092927510
No problem. I should be able to answer most of these.
Where did you get yours and how much? On eBay, I linked the auction in a few posts above, but the Site Sponsors here will be able to get it for you.
Did you have to get new shocks too with the set up? No need for shocks, I just wanted to buy them for additional travel and ride quality.
If you had to do it all over again, what would you do differently? Nothing at all, this is what I wanted to pacify me until I go bigger. The kit is very nice, high quality spacers, and takes less than an hour to install.
Also, how bad does this impact the warranty? Always a tricky question with any modification on any vehicle. This depends on the dealer, and what the warranty work being performed involves. If this lift or any modification you perform is directly associated with, or caused the failure/issue, then your warranty for that issue would not and should not be covered. A lot of Jeep dealers are modification friendly, but some are not. This lift is so mild, most dealers would not even know it is installed. The Magnusson-Moss Act also protects you to a certain extent with warranties. For example if you lifted your JK, and your door falls off due to faulty hinges, they cannot deny your warranty claim on the door because you lifted your Jeep.
