35's on stock rims?
Old Apr 9, 2007 | 09:47 AM
briandunning's Avatar
Default 35's on stock rims?
I am going with BFG Mud Terrains, 35x12.5 17. Does anyone know if there's a problem keeping my stock rims? Are they wide enough? Rather not spend money I don't have to. I am aware that I'll need the Spidertrax 1.5" spacers. Thanks.
Old Apr 9, 2007 | 10:01 AM
FRDesign's Avatar
12.5's should be fine. Theres a few people running 12.5" tires on the stock rims
Old Apr 9, 2007 | 10:02 AM
IGOFSHN's Avatar
I've had no problems and I don't expect any.
Old Apr 9, 2007 | 10:51 AM
Roadtrip's Avatar
I've got em, they work like a champ... Except the spare.
Old Apr 9, 2007 | 10:55 AM
What is the problem with the spare? (And what's the solution?)
Old Apr 9, 2007 | 11:18 AM
Roadtrip's Avatar
Offset on Stock rims is to much to mount on the standard spare carrier... I just posted about the Best Top High rock carrier... a second ago actually... It'll hold it.
Old Apr 9, 2007 | 04:59 PM
Renegade's Avatar
Depending on exactly which tire you put on, and your level of persistence, you CAN fit a 315/70-17 (34.5") spare on the rear without modifications. I have done it as have some others. You may need to trim the stock tailgate spacers.
Old Apr 10, 2007 | 05:34 AM
JKMAN's Avatar
or you can throw a spacer on the spare as well and run a 35" with no issues/trimming.
Old Apr 10, 2007 | 05:26 PM
luckie44's Avatar
Default Renegade...
Are you saying use on of the Spidertrax spacers on the stock rear tire carrier? If running the Hankook's like yourself?
thanks in advance!
Old May 8, 2007 | 02:12 AM
Colonel Angus's Avatar
Does anyone know if 35x12.5's will fit on the stock 16x7 rims?
