Bump stops / OME - 35's
Old Dec 17, 2008 | 10:53 AM
Windrocker's Avatar
Default Bump stops / OME - 35's
What are you guys with the OME HD setup with 35's running for bump stops?
Old Dec 17, 2008 | 10:55 AM
wayoflife's Avatar
JK-Forum Founder
while i'm not running an OME lift, i have installed one before and based on what i have seen, you should run a 2" bumpstop extension and perferably, one that gets mounted to the axle.
Old Dec 17, 2008 | 11:29 AM
Northridge4x4's Avatar
Sponsoring Vendor
We will have bumpstops kits for the OME kit in 2 weeks.
They will run about $75 or so for front and rear.
David
Old Dec 17, 2008 | 11:35 AM
armycop's Avatar
I ordered a set of aluminum 2" bumpstop extensions for my lift from Full Traction directly. They charged me $60, but you have to call them and special order on the phone 1-800-255-6464. My order came in a few days.
Old Dec 17, 2008 | 12:36 PM
Windrocker's Avatar
David
Thanks David for your help with the bump stops and getting them to me a little early . They will be put to use at the upcoming JK-South ride at Coal Creek right after Christmas.
Old Dec 21, 2008 | 09:14 AM
Stampsjk's Avatar
David
Dave,
I have the OME hd kit with 35s. I went wheeling this weekend and was rubbing all over the fenders. Please let me know when I can get the kit.
Thanks
Old Dec 21, 2008 | 09:31 AM
Captain Hook's Avatar
Originally Posted by Stampsjk
Dave,
Thanks
DItto.....I have an OME HD and 35's, and a 1" body lift and still some rubbing on extreme flex. I need bumpstops
Old Dec 22, 2008 | 08:40 AM
bigbluejk's Avatar
Is there any reason I couldn't use the bumpstops that came with my superlift 2" spacer lift with the OME kit?
Old Dec 22, 2008 | 08:48 AM
Sponsoring Vendor
No not at all.
We will have these in stock after x-mas or you can call me and we can drop ship them for you today.
they run about $75 for front and rear.
David
Old Jan 20, 2009 | 04:23 PM
m(a)ce's Avatar
Question
Do you need (or suggest) anything else to run the 35s on OME HD (assuming you have the specified weight) apart from f&r adj trackbars?
with the lift yielding more in the 2.5"+ range, do you need new rear links (& move rear to front), for example?
(the Northridge long travel OME kit looks good & damn tempting btw)
