Rock Krawler 3.5" Entry Level System
Old Jan 1, 2009 | 03:15 PM
JKBully's Avatar
Default Rock Krawler 3.5" Entry Level System
Is there anyone on here running this lift? If so, I'd love to see some real world shots of it and possibly some before and after measurements.
Thanks in advance!
Old Jan 1, 2009 | 04:52 PM
Phishjeep's Avatar
I run their 3.5 inch Long arm, so I don't know much about the entry level kit other than to say their quality and service are top notch. You won't be disappointed, and everything is upgradeable to the next level kit and beyond
Old Jan 1, 2009 | 05:09 PM
JKBully's Avatar
That's what caught my eye about the system. That, and the price is pretty good! I think it would be the same amount of lift, no? The only difference is that you have the CA's, right?
Old Jan 1, 2009 | 05:28 PM
Phishjeep's Avatar
well the long arm gets into a bit more (kind of like the Xfactor plus swaps to a three link rear. The long arm is 3 link front and rear. The x factor is very similar to the FT ultimate or the Currie, or the Clayton, for example. Four link front and rear. 8 adjustable control arms and adjustable track bars. The entry level system is (I believe) springs and track bars. Then you can upgrade the control arms as you need them.
The height should be similar, but I don't know for sure. I got about 5.5 inches out of my 3.5 inch kit. Maybe it will settle some.
If you are two door, you may want to add upper adjustable control arms, becuase you'll likely be replacing your rear driveshaft soon.
If you are auto, you may want lower adjustable front control arms for the same reason.
And the control arms are SOLID steel!!!!
Phishjeep's Avatar
Call rockKrawler and talk to Jeremy.
Old Jan 1, 2009 | 05:37 PM
JKBully's Avatar
Cool! Thanks!
Im in an Unlimited 6spd.!
Do you have any pics of your rig?
