Full-Traction 6" LA - Home Build
I started this project having little to no knowledge of JK's. I had a 1951 M38 before this, so the project provided a huge learning curve. In the end, it took me about two months to complete in the evenings and on weekends. I waited nearly 7 months for all the parts to arrive so I could start. I at least have the confidence of knowing how the jeep was put together and that it was done right. I know there are quite a few pics, but wanted to share some of the aspects of the build. So far, I am very satisfied with all the choices of parts and their preformance. This was because all I learned here on this site before I began....thanks.
Before the transformation
[IMG]
[/IMG]
Starting the work
[IMG]
[/IMG]
Removed control arm brackets and prep'd
[IMG]
[/IMG]
Added EVO C2 Gussets
[IMG]
[/IMG]
Shocks too short...made custom relocation brackets
[IMG]
[/IMG]
Relocated rear brake lines to avoid rubbinbg at full-stuff
[IMG]
[/IMG]
Finished mounting all 5...kinda a PITA
[IMG]
[/IMG]
Relocated evap can w/Woods' help
[IMG]
[/IMG]
Fitting Rock Sliders
[IMG]
[/IMG]
Mock-up Front done
[IMG]
[/IMG]
Final wiring and fit for rear...after mfg emblem filled with steel!
[IMG]
[/IMG]
Finally done...ready to use
[IMG]
[/IMG]
It's all worth it in the end
[IMG]
[/IMG]
[IMG]
[/IMG]Starting the work
[IMG]
[/IMG]Removed control arm brackets and prep'd
[IMG]
[/IMG]Added EVO C2 Gussets
[IMG]
[/IMG]Shocks too short...made custom relocation brackets
[IMG]
[/IMG]Relocated rear brake lines to avoid rubbinbg at full-stuff
[IMG]
[/IMG]Finished mounting all 5...kinda a PITA
[IMG]
[/IMG]Relocated evap can w/Woods' help
[IMG]
[/IMG]Fitting Rock Sliders
[IMG]
[/IMG]Mock-up Front done
[IMG]
[/IMG]Final wiring and fit for rear...after mfg emblem filled with steel!
[IMG]
[/IMG]Finally done...ready to use
[IMG]
[/IMG]It's all worth it in the end
[IMG]
[/IMG]
The frame looks alot cleaner than I made mine!!
