"X" unlimited & 37's ????
I saw an unlimited on 35's or 37's, couldn't really tell the distance, but I was wondering whether or not the "X" unlimited can handle 35's or 37's (for that matter).
Can the front dana 30 handle 37's if the wheeling isn't extreme. I plan to go on moderate to light aggressive wheeling. I cant afford the rubi at this time, but thought that the x may suffice.
Is anyone wheeling an X on 37's?
Pics, Pro's, and Con's are appreciated.
Brian
Az
Brian
Az
My buddy JCAD has an X with stock rears, 6000 miles on 37's with no problems at all.
there are a bunch of pics in here
https://www.jk-forum.com/forums/jk-show-tell-33/finally-my-2dr-6-lift-37s-33122/
If your not going to do all out rock banging, river forging, dune jumping, wheeling. I think the Dana 30 with some slight mods will be just fine.
I would suggest installing, the EVO C-2 Gussets, (the Jeep C's are a very well documantaded weak point) and a set of Chrome Molly Axles.
If your going to do just some light to moderate wheeling with say 33" tires the stock Dana 30 would be just fine.
The added weight and overall work load of larger tires are what kills the Dana 30.....
This is just my
for what it's worth..........
This is just my
With the right modifications and being careful with your right foot you'll be fine. 35's are definitely not an issue with the D30. 37's can be done and a few are running it but you just want to be that much more cautious.
Here's an X Unlimited on 37's competing in a speed crawl competition
run #1- broke the D30 axle shaft: http://www.youtube.com/watch?v=MWDgyY2j8Ko
Run back to the pits and replaced the shaft with a Alloy USA chromoly shaft and then run #2- http://www.youtube.com/watch?v=e7K8S4o_4OQ
Yogurt, I hate Yogurt, especially with strawberries.(sorry I couldnt resist!)
I know its no 44 but it aint that bad
I think we all have said that when we first started building our jeeps. Fast forward a little and you will find yourself trying to climb some waterfall you swore you would never do. Welcome to the battle of the walet.
