Bulletproof Steering
Old Jan 16, 2009 | 10:27 PM
UCLA JK Rida''s Avatar
Default Bulletproof Steering
What up peeps?
I was getting rather tired of the "shimmy shimmy Cocoa Puffs" that my front end was giving (due to my bent tie rod) me every time I hit a bump in the street. So, I decided to shore things up and make the front end as bulletproof as I could make it.
I threw on the Teraflex HD reverse draglink, the Teraflex front trackbar bracket, a new JKS adjustable front trackbar, some 1-ton tie rod ends, and lastly, the Pièce de résistance, the Rock Krawler HD tie rod. This thing is a straight BEAST! You could ultimate giga knock someone out with this joint. Okay, the pictures follow. Enjoy!
This HD tie rod, much like the Last Son of Krypton, is bulletproof.
Shot from the passenger side front of all my new steering goodies.
Up close and personal with the Teraflex Front Trackbar bracket. This piece is a direct bolt on unit, but I'm thinking I might shore it up with a couple of welded beads in the future (just to be on the safe side).
Another shot of the ultimately ruthless Rock Krawler HD tie rod (this bad daddy is 1.625" in diameter...and made of solid steel).
Russ D.
Old Jan 16, 2009 | 10:38 PM
lc619fr's Avatar
I bet that SOB was heavy, I just got my Teraflex Control arms (thanks dave) and only four of them wieghed in at 46 pounds
Old Jan 16, 2009 | 10:43 PM
Yeah, the tie rod BY ITSELF weighs 35 lbs.
Russ D.
Old Jan 16, 2009 | 10:54 PM
Snap-Off's Avatar
How much of a difference did it all make? I'm sure its handling is in lambo territory now
Old Jan 16, 2009 | 11:05 PM
Snap:
Maybe not quite Lambo, but at least Acura Integra territory...ha ha ha ha ha.
Russ D.
Old Jan 16, 2009 | 11:10 PM
Originally Posted by SONIC
Dayum russ lookin good mayun!
Thanks, Sonic! It feels muy bueno, as well.
Russ D.
Old Jan 16, 2009 | 11:25 PM
i bet.
i need all that stuf but funds are lacking severely at the moment.
mine is squirley as hell!
Just remember, squirrels are tasty with some A-1 sauce.
Russ D.
Old Jan 17, 2009 | 03:42 AM
yoshillopez's Avatar
Russ -
Quick question about the Teraflex Trackbar bracket....is this available separately or is it part of a kit you have to buy. Did you have to drill in the frame? If you don't mind me asking, how much did it cost.
Much mahalo
Josh
Old Jan 17, 2009 | 05:36 AM
jkkat's Avatar
Looks great so far. One place you missed on the the stock front track bar mounting bracket on the axle, you might want to rebuild it thicker or gusset it.
Old Jan 17, 2009 | 06:00 AM
Roxster's Avatar
Originally Posted by yoshillopez
Russ -
Much mahalo
Josh
I'm also interested in this. I have the JKS adjustable track bar, so my axle is centered. Does the bracket improve the geometry of the track bar, and with what being the benefit? Nice installs.
