1" Front coil spacer for FT lift
Well, I have a PUREJEEP front bumper and WARN PowerPlant so my Jeep is raking a bit too but once I'm all loaded up with passengers and/or with gear for the trail, I've noticed my JK sits totally level. In other words, I suspect that if I raise up my front to level things out unloaded, once things are loaded, my rear end will be sagging. Need I say, you may want to reconsider getting rid of your rake. But, if you're still determined to do so, I'm sure it can be done with ease
well I used a 3/4 spacer allong with my 3" FT eco lift to help level it out. it still may be a tiny bit lower in the front but it's not very noticable if it is. and while I under stand what WOL said when I took a vacation to disneyland for a week I had my rig loaded up with suitcases for my wife , daughter, and myself, then we had a tote of food and other stuff then my dog (yellow lab) in the back so I would say we were prety loaded up and it did'nt sag out the back on me...
I also have the PJ bumper and the Warn winch. I talked to FT about the sag and what options they would suggest. They suggested a beefier front coil. I ordered the new front coils throught FT. Once I get the new coils delivered and installed I will post pictures and info.
Beefier front coils? Stiffer? How will that affect the ride quality? Or are the just taller front coils?
When you saw me last, I had them on my JK and can tell you that they did not effect the ride quality at all. But, if you don't have an aftermarket bumper/winch, your front end will sit too high and it may ride funny.
This is a pricture of the orginal coil with the bumper and winch installed.
Good to hear you like them. I feel better about installing them now. FT said that if I ever want to take off the bumper and winch I should replace new coils with the originals.
