Show your CB mounts
I'm looking to put a CB in my JK. Please post pics of how you guys have mounted yours. Has anybody used the Cobra 75? It looks like it would be the best suited for the JK's lack of space. Any thoughts?
I need ideas for antenna mounts too. Thanks.
My Cobra 29 in the glovebox, plenty of guys are mounting the 75's under the glovebox just remove the lower panel under your box you should have enough room room for the 75 there and my antenna mount is right on the spare tire carrier but I deleted the rear so its on the gate in the same spot 3' Wilson
Here is mine and w/ a write up for the external speaker.
I also have the cooltech versa mount and there antenna mount
https://www.jk-forum.com/forums/show...ternal+Speaker
I bought a piece of shelving bracket at ACE. I flattened out the ends an bent them around and under the console lid. I made the mic mount from a template I found on this site. https://www.jk-forum.com/forums/show...ight=mic+mount
