JK Unlimited X
Old Nov 13, 2006 | 05:00 AM
Quebec4x4's Avatar
Default JK Unlimited X
They JK where i work
2" spacer kit with 35"
http://www.sdlsuspension.com/divers/jk07/PB091894.JPG
Old Nov 13, 2006 | 05:34 AM
emorick's Avatar
What lift is that, TeraFlex? Are those 35 x 12.5 x 17 on stock rims????
Old Nov 13, 2006 | 05:56 AM
Quebec4x4's Avatar
Full Traction
315/75r16 on stock wheel
1.25 wheel spacer
Old Nov 13, 2006 | 06:35 AM
dhoffroad's Avatar
looks nice !!!
jeep should have put 35's on stock, they just have that "perfect fit".
so do the 1.25" spacers leave enough room or would you sugest someone go with the 1.5"ers...
Old Nov 13, 2006 | 08:56 AM
Rubimon's Avatar
Originally Posted by dhoffroad
looks nice !!!
Use 1.5", that way you won't have to cut off your studs. Sounds painful!
Old Nov 13, 2006 | 08:59 AM
Rubimon's Avatar
Originally Posted by Quebec4x4
Full Traction
1.25 wheel spacer
What tire brand are they?
Old Nov 13, 2006 | 10:06 AM
Quebec4x4's Avatar
the tire was a Procomp MT
the 1.25 spacer was enough, only need to remove the front plastic cover under the bumper. We dont cut the stud, we dont use open nut also (the one in the kit dont have the good thread, too cheap) ... but will be better with open nut. With 1.50, here with the law, we will need fender flare...so it's a good combination.
in the 2" kit, they dont have a rear trac bar bracket, so the rear axle was not center.
We will change the 2 rear shock, too short.
another shot :
http://www.sdlsuspension.com/JK/JK_sdl.jpg
Old Nov 13, 2006 | 12:45 PM
Quebec4x4's Avatar
very easy to enter ... easier than a TJ, no entry step like a YJ TJ ....
plus facile a embarquer qu'un TJ
Old Nov 13, 2006 | 01:23 PM
Rubimon's Avatar
OUI! OUI!
Old Nov 15, 2006 | 08:23 AM
Quebec4x4's Avatar
sorry i dont have.
