Welding up the Dana 30
Old Jan 24, 2009 | 09:07 AM
Geeper4x4's Avatar
Default Welding up the Dana 30
We will be welding on the Dana 30 this week. If anyone has suggestions or ideas that would be helpful please post. I intend to reinforce the C2's and will put a truss across the the top of the axle. The truss is probably not necessary but it won't hurt anything. I do know that I will need to keep the C cool to not ruin the grease in the joint. I will use wet rags and short welds to keep the temp from building up. I will also cover the lower control arm attachments. I will post pics as we make progress.
Old Jan 24, 2009 | 09:30 AM
wayoflife's Avatar
JK-Forum Founder
it's sounds like you've got things covered when it comes to the C2's but you really need to be careful when welding on a truss as doing so can easily bend your axle tube.
Old Jan 24, 2009 | 10:22 AM
RedneckJeep's Avatar
We used to just weld angle iron on the top and bottom of axles as reinforcement. It doesn't require a lot of room, but is very strong. It works well.
Old Jan 24, 2009 | 10:28 AM
CLACKEY(_!_)'s Avatar
Space the welds and allow them to cool. If you get the axle hot it WILL warp!
Old Jan 24, 2009 | 03:25 PM
Geeper4x4's Avatar
Thanks for the input. I appreciate those that know more helping out with my projects.
Old Jan 24, 2009 | 05:44 PM
chuck45's Avatar
I've been thinking of welding on Rock Krawlers truss. Is there a proper procedure to follow to do so such that it wont warp? Or would I be better off to go with the Mount Logam sleeve? That is assuming the sleeve can be used with AlloyUSA front axles.
Old Feb 7, 2009 | 12:22 PM
Geeper4x4's Avatar
Welded up the area in front of the lower control arms. Didn't have time to get much done this week.....It's a start on the Dana 30 build.
