Rough Country = NO lift
OK, I'm just a little confused....
I started with a 1.75" spacer lift front/rear...then added 3/4" spacers to the front to equal 2.5" front/ 1.75" rear. I recently purchased and installed the Rough Country 2.5" Coil Kit with the 2.2 Shocks...I left the 3/4" spacers in the front, and purchased some 1" spacers for the rear. So, in theory, the front should be lifted about 3.25" and the rear about 3".
OK, so I didn't take before and after measurements like I should have...and it just doesn't look any higher than before...I mean, it should be at least an inch higher in the rear and about 3/4" in the front but it looks the same if not shorter!
Tonight I went to the dealer and measured a stock 2-door...took out the tire measurements so that wouldn't be a factor (my tire measures 32" tall, stock was 30.5"...took out 3/4" for the tire measurement). When measuring the rear, the actual suspension lift I have is about 3/4"...and the front actual lift is about 2.5".
The front I can deal with I guess, but the rear only being 3/4"?? I mean, I even have a 1" spacer on top of the coil which is supposed to create 2" of lift by itself!!
Am I figuring something wrong here? Here's a pic of mine with the new coils and spacers....does this look lifted about 3" to you??
Here's before with just spacers 2.5" front/1.75" rear...
And now with the 2.5" coils with spacers on top....
My RC 2.5 coil lift with shocks was 3" in the front and 2.5" in the rear. I took multiple measurements from various hard points and used a carpenters level to make sure I wasn't skewing the measurement.
"Eyeballing" is a pretty tough way to detect 1" I think....I have enough trouble getting a picture stratight in the living room that way.
Mine is a 4 door, but why don't you take specific measuresments from identifiable points, and then post the results. Someone who has done just the lift can then probably measure their 2 door and see what you really have.
