Steel tubing...where?
I am looking into fabbing up some custom parts for my jeep(roll cages, etc). However I am having a heck of a time finding someone who sells seamless steel tubing. 1/8inch thick and 2 inches in diameter is what im kind of looking for, but would like a selection to choose from. Anyone know a distro of this type of steel? thanks!
EDIT<changed the thinkness to 1/8, dunnon what I was thinking when i wrote 1/16>
I am looking into fabbing up some custom parts for my jeep(roll cages, etc). However I am having a heck of a time finding someone who sells seamless steel tubing. 1/16inch thick and 2 inches in diameter is what im kind of looking for, but would like a selection to choose from. Anyone know a distro of this type of steel? thanks!
Seamed or seamless the integrity of the pipe is equal around it's cicumference or there would be no market for it.
The two most important rules for manufacturing pipe are: - must withstand pressure
- must have continuous hole from end to
end
Why is seamless so important in your search?
end
end
They make something like that but my local suppliers don't stock it as there is no call. It's only Schedule 5. Go here and you can see a listing of what is available:
hxxp://www.maselmon.com/Content.aspx?ContentID=24
I'm lookin for the same kinda thing, but stock we lots of sizes & shapes of steel at my work & i have access to it, just not the size im after. We will be ordering some for 'engineering projects' though I think.
It also may be easier to find 2"OD x 11ga (0.120) instead of 1/8"
I would suggest trying any of the following shops listed as fab or machine shops in the phone book.
I googled it, and found:
hxxp://www.fabshopweb.com/shopsA2Z/PAm2z.htm#york
I dont remember York being that industrial when i was there, but I was pretty 'sheltered' i guess.
DOM tubing: Roll cages and suspension links.
Welded seam tubing: Bumpers, brush guards, and other things similar. (DOM still being best but welded seam much cheaper)
Conduit: keep it on your walls and in the ground for wiring.
Pipe: You could use it for bumpers and brush guards but I'd rather use welded seam.
And for about $600 you can get a bender that works great. You'd have to spend $7-10k to get a bender that could do a nicer job (Mandrel bender)
