Should this look like this?
Old Jan 26, 2009 | 02:41 PM
JeepyJeep's Avatar
Question Should this look like this?
Newb question...
So I was sniffin' under the Jeep just now and saw what I beleive to be the sway bar link on the passenger side in a less than flattering pose, i.e. not seated properly, bottom and top, as compared to the link on the driver side.
Attached,(hopefully) are photos of the two.
Is my diagnosis right, i.e. is the passenger sway bar link connected incorrectly? Or is supposed to connect like this? I have an Electronic Sway Bar disconnect, and have not been afraid to use it, if that helps in answering my question.
FYI 3 in. Black Diamond Lift
Passenger side:
Driver side:
Help...
Old Jan 26, 2009 | 02:44 PM
Chukronos's Avatar
What?! I am not sure if you are joking or not. If not, the passenger side is screwed in on the wrong side. The bottom should be on the inside of the mount, like the Driver's side.
Old Jan 26, 2009 | 02:47 PM
ytee's Avatar
It appears that your axle is shifted to the passenger side of Jeep. Did you install an adjustable track bar when you installed the lift? If so the track bar may need adjusting.
Chris
woolf's Avatar
What chuck said
Old Jan 26, 2009 | 02:49 PM
ytee's Avatar
Duh I did not catch that!
Old Jan 26, 2009 | 02:57 PM
JeepyJeep's Avatar
Default Chukronos...nice catch is right...
Thanks, now that you point that out... it's obvious...doh!
THANKS AGAIN...callin shop that put it in...pronto!
Old Jan 26, 2009 | 03:13 PM
Cesar's Avatar
hey even though it was obvious...I give you an A+ for effort.
You did the right thing and consult. I couldnt tell you how many times I have consulted with my buddies and they laughed at me.
Old Jan 26, 2009 | 03:32 PM
Augie's Avatar
Consulting also leads to other things to look out for. For example, is your axle centered with jeep, if not, adjust your track bar. If your lift has not settled, when it does, re-adjust the centering of your front axle to the frame via track bar, then recenter your steering wheel.
Old Jan 26, 2009 | 03:33 PM
JeepyJeep's Avatar
Default Corrected!
Still embarrassed...but I can still use the newb excuse...for awhile anyway.
THANKS AGAIN GUYS!
Old Jan 26, 2009 | 03:36 PM
Biggerjeep's Avatar
ohoooohohh
