rear track bar needed?????
Im running 6 inches in the rear with stock driveshaft and track bar. Not to say that i am going to upgrade down the road. My rear axle is about an inch off center, but it hasnt affected the drivability or treadwear on the tires.
That will help. Just be careful that the stock bracket does not get over stressed. All of the factory mounts are fairly weak and adding length can make them worse.
I see that you are close to me. If you need any help on the install or someone to go wheelin with send me a pm and i will be glad to
