Spacer lift or spring kit for a rubicon
Old Jan 26, 2009 | 10:32 PM
zacsquatch's Avatar
Default Spacer lift or spring kit for a rubicon
So, 07 rubicon 4door. But what should I do... Keep the stock rubi springs and run the 2.5 spacer lift... or get a spring kit and get a whole different feel..
Old Jan 26, 2009 | 10:38 PM
wayoflife's Avatar
JK-Forum Founder
how big of a tire do you plan to run and what kind of budget do you have to play with? if you have a boat load of cash, a coil lift with control arms is definitely the way to go but if you're on a budget, there's absolutely nothing wrong with a spacer lift. a 2.5" kit and a 1" body lift will get you riding on 35" tires and without any problems.
Old Jan 26, 2009 | 10:56 PM
zacsquatch's Avatar
It'll be a set of 34 skinnies or 35 12.50's with some 1" wheel spacers... Not going to be a major flex machine, just a lil more meat for the trail. I plan on some Bilstien remote res. shocks too, lots of rough pot-holed trailes up here... Shocks have been known to warm up a bit, haha.
either way, spacers or springs, I'm stickin with 2-2.5"
Old Jan 27, 2009 | 02:46 AM
nclehmann's Avatar
I'd run springs, but I would probably go 3" if you plan to run 35s. You're going to rub if you only lift 2" - and not only at full flex. Maybe go with 33s if you want to stay at 2" of lift. There's plenty of 33" pizza cutter tires out there - more than 35s at least.
Good luck.
Old Jan 27, 2009 | 06:00 AM
derekls's Avatar
OME.
Old Jan 27, 2009 | 06:03 AM
Westbayou's Avatar
Seems like a 2.5" Rough Country coil lift w/shocks and a set of 34's would be a pretty sweet setup without breaking the bank. Running 35's you'll want to go bigger, trust me.
Old Jan 27, 2009 | 06:19 AM
nclehmann's Avatar
That would be a great setup. A few folks on here are running 2.5" with 34s. I think that Goodyear makes a set of MT/Rs in 34" that aren't too wide (305s I think).
Old Jan 27, 2009 | 10:29 AM
zacsquatch's Avatar
OME's xj kits were soft, and it seems they didnt take to holding much gear... now are their coils all around on these things..
