spyderlocks wheels rubbing on brakes ??
i just got my new spyderlock wheels .. put them on and both front wheels are rubbing on the inside on the brakes ? they started grinding .. i never read about anyone having problems with these wheels rubbing on the brakes ? i have the 18 " wheels .. anyone ever had this problem.? thanks for the help ..
they only come in 3.5 i dont this its that. the problem is the area in the center is to wide.. i think they used the wrong blank wheel to drill a 5 x 5 pattern .. it says 8 lug on the inside..?? but it has been drill a 5 x 5 . i never heard of anyone else having problems.
ok finially got ahold of someone from kmc the makers of the spyderlock and they forgot to mill down the inside to the correct size when they drilled them
atleast they are sending me new ones
but that means more waiting ....
they sent three sets , the first set the pad on the back wasnt milled down enough to fit a 5 lug .. it would fit a 8 lug... second set they sent 17 inch instead of 18 " then the third set was correct
alittle bit of hassle getting them mounted.. but worked that out. they are on and im happy ! i did get a extra set of beadlock rings out of the deal.. they are at the powder coaters right now . so in the end everything worked out .. just took awhile ..
thanks alote man.... im still waiting on a few things... like the rear tire carrier from offroad evolution. and rear armor.. but yeah im really happy with it .. the other set of beadlock rings im getting powder coated and black/green .
