Custom rock rails redone
So, I took the rock rails I made a couple of months ago off, added some support, and "skinned" them. I took some leftover sheet metal I had laying around and covered the top of the rails so I have somewhere to put my foot when I have the doors off and don't have to worry about taking a rock to the bottom of my foot from the tire.
This is what I originally made and many of you told me to add braces between the round and square tubing.
So I added some 3/16" plate braces.
Then I welded on some leftover sheet metal, ground it smooth and sprayed on some DIY bed liner.
Great work on those man!!! I think they look fantastic! If you want to come do mine... I would let you.
The body mounted rubi rails and enhanced rubi rails hold up just fine. Bomb proof? No. Personally, I have come down very hard on a rubi rail with no evidence of impact. You see very few pics of damaged rubi rails on this site.
It's a bit silly to imply that these are useless if not mounted to the frame.
If anyone want's a set I'll make them with 3 body mount braces and all 6 body panel bolts. I've thought about frame mounting, but this is easier and I can't see them going anywhere. Also, they are less bulky under the Jeep when made this way.
Here is a pic of the front body mount that I used. I also used the middle body mount and 4 bolts to the body itself.
last time i checked body mounts were made to be somewhat flexible. dont get me wrong they look great but i smashed my stocker rockers into the body and they pretty much mount the same as yours.
