Have you installed your own axle shafts?
Has anyone installed their own rear superior axle shafts? I picked my up today after having the tone rings and retainers installed. I'm planning to install them this weekend and was looking for any tips or issues I may face with the install.
I haven't on a JK, but I did a set on my TJ. Take off the caliper, rotor, and unbolt the retainer plate. I used a slide hammer I had to help in popping them out of the axle as they were engaged in the splines pretty tight. Overall it was pretty easy, probably 45 minutes start to finish for both sides.
Double check your wheel studs for length. I'm running Spidertrax wheel spacers and the ones that came with mine were too short. I had to get a set of 2 1/4 inch ones from them. They thread into the axles instead of being pressed in them. If you have no instructions, Chuck45 says they told him to torque them into the axle @ 70 FtLb and use plenty of red Loctite on both the threads going into the axle and on the threads for the lug nuts.
Should be a piece of cake, did mine in a hour or so. Two things, while you have the caliper off, adjust the parking brake. It's easier to get to the little adjuster hole. Second, I put some rtv inside the retaining plate before I bolted everything up.
