Bumper installation ????????????
Old Jan 29, 2009 | 03:51 PM
cslack19's Avatar
Default Bumper installation ????????????
I just got my new bumper (SMITTYBILT XRC) and was wondering, can I reuse the factory fog light wiring for new fog lights. for example a set of kc daylights?
Old Jan 29, 2009 | 04:01 PM
tambil68's Avatar
You would have to check on the power requirments. I believe most people have had trouble using the factory wiring. But you should be ok if you don't go larger then the wattage of the factory fogs. And it's not the wiring size, rather it's the can bus system seeing to much power being pulled from the lights that makes the computer shut down that circuit.
Old Jan 29, 2009 | 04:06 PM
cslack19's Avatar
wow! I didn't think it would be that involved. I thought u just take the factory lights out and put the new ones on. If the new set of lights come with the wiring harness and everything should I use it.
Old Jan 29, 2009 | 04:07 PM
cslack19's Avatar
is it hard to install new lights and wiring?
Old Jan 30, 2009 | 01:52 AM
yoshillopez's Avatar
Its pretty easy and straight forward. Yamaha90 has a write up in the write up section. I had never wired lights before, used his write up, and had no issues.
