oil pressure gauge/sending unit installation
has anyone installed an aftermarket oil pressure gauge in their jk? if so how did you connect the sending unit to the oil filter adaptor? the plug on the adaptor is metric thread and i cant find any sending units with metric thread. i trying to find ideas on how to make this work. thnks
Why not just the port where the stock sender gets it's input from? I don't know where it is, but it shouldn't be hard to find. All you'd need is a brass "T" fitting and whatever hardware comes with your new gauge.
don't know the size but its gotta come off anyway, take it off, take down to a good hydraulic shop and ask someone who knows what they're talking about to size one up for you.
Oh yah, keep us posted I've always thought of this too as the low oil pressure light doesn't come until pressure goes bellow 4psi, to me its to late by then. Why not 10-20psi warning.
That's what I did with a similar situation on the tranny temp gauge...also, once plumbed I found out that you have to ground the sensor (thanks Autometer TS for your help) and using a hose clamp with 18 guage wire grounded in the engine bay worked out just fine.
im in the process of trying to fit a guage to my car for the oil pressure, i got the guage fitted and the fittings just need to find a deep socket to remove the switch to see if the t fitting fits. ill post photos when im done oh and the p/s size is 3/8 npt from what icould find. its in a realy bad spot to remove too. fingers crossed i can get it out. ill keep you posted
got it fitted today lads. pics in aweek or so im going on holiday,
The thread is a 3/8npt on the pressure switch, u require a 1-1/16 SINGLE HEX DEEP SOCKET to remove the original pressure switch. in stall a MFF T peice 3/8npt also. the point the rotating F end between the radiator hose and engine mount, in the same port screw a 3/8npt extension then into that a 3/8-1/8 reducer and install your new pressure switch sender. in the old port fit the original pressure switch. as i said i got photos just going away tomorrow and wont have a computer. works the charm tho.
USE HIGH PRESSURE THREAD SEALANT ON ALL THREADS OR U WILL HAVE LEAKS !
enjoy.
enjoy.
