Warn Powerplant duty cycle
Old Apr 27, 2007 | 12:52 PM
jeffmarion's Avatar
Default Warn Powerplant duty cycle
Does anybody happen to know what the duty cycle is on the warn powerplant?
I already have the Viar constant duty onboard air system http://www.viaircorp.com/10007.html waiting to be installed, but the powerplant flows alot more air.
Warn High output- 5 CFM @ 90 PSI
Viar 450C .97 CFM @ 90 PSI
Plus space is really limited on the JK for this system. Although the cost is another factor, I could potentially save about $400 going with the Viar and T-Max EW-10000W OUTBACK. Decisions... Decisions.....
Old Apr 27, 2007 | 12:59 PM
BLKRUBI's Avatar
I know, I know, that's for when you need to stop on the trail and take a duty.
Wait, how come it's called taking a duty and not leaving a duty, after all, you're not actually taking it anywhere, are you?
No?, OK, sorry, I have no clue then.
Old Apr 27, 2007 | 02:03 PM
Piginajeep's Avatar
Its not listed on the site. I havent had mine overheat. But I havent used it alot yet either. Are you going to put the powerplant 2.5 gallon tanks as well? I would suggest that upgrade or the compressor will never stop running.
Old Apr 27, 2007 | 07:10 PM
Andrews's Avatar
Those of you with the PowerPlant - is the cycle long enough to air up 4 tires from nearly flat to 40-50 psi? That's probably the most I would need it to do...
Old Apr 27, 2007 | 07:13 PM
Piginajeep's Avatar
DEFINETELY..... Its airs them up rather quickly.
Old Apr 28, 2007 | 08:42 AM
shrockworks's Avatar
Former Vendor
I've aired my 37" up from 12 to 32 psi 15 or 20 times. I love the the thing. I've only used the winch once but I've used the compressor about 20 times. It rocks.
Old Apr 28, 2007 | 11:13 AM
jeffmarion's Avatar
Jim, are you using an air tank, or coming straight off the compressor?
Also, about how long does it take to air up your 4 tires?
Old Apr 28, 2007 | 01:51 PM
Former Vendor
No Tank....it would only help on the first tire....maybe. Would allow impact wrench though.
Dont know how long, but it's pretty damn quick....I'm not very patient and it seems fast to me. I'd guess maybe 2min a tire max....but that is a guess.
Old Apr 28, 2007 | 01:55 PM
Piginajeep's Avatar
Yep, your right. I would guess about that long a tire.
I put the tank on the back compartment LID. Its quickly removeable with wing nuts. So I can put it in the jeep when I need to. I can also still use the compressor without the tank. just an Idea if your cramped for space in the 2 door like I am...
