Body lift help
did you disconnect the steering shaft when you lifted it? if not, maybe your getting some bind there?
Edit: My 1" body lift didnt come with an adapter, no need for it, plenty of room on the stock shaft for what little bit it extended.
under the hood, on the driver's side, the steering shaft has a (13mm?) bolt on a slip joint connecting the two pieces. Loosen the bolt and slide the joint to see if there is any bind?
The instructions for the Perf Accesories 1 & 2" lifts show this, you can read through it here: 992
that is the 2" instructions, i couldnt get the 1" ones to download, just ignore the adapter.
did you get the instructions in the 1" kit? I know it shows that step in there (at least it did on mine)
I hope that helps?!
I hope that helps?!
