Ome lift, shock question
Old Feb 11, 2009 | 10:58 AM
08JKER's Avatar
Default Ome lift, shock question
I LOVE my OME lift but i think the shocks are limiting!?!
how long of a shock can i go with, without loosing my springs?
Old Feb 11, 2009 | 11:06 AM
Northridge4x4's Avatar
Sponsoring Vendor
They are! and are meant to to be honest. If you want to run a longer shock you will need to address the brakelines and sway bar links .
David
Old Feb 11, 2009 | 11:56 AM
08JKER's Avatar
extended brake lines are on the way and sway bar links are installed. how long of a shock should i go to? i know the OME's are 24 inches long.
Old Feb 11, 2009 | 12:14 PM
Sponsoring Vendor
Then you could runs these and now just be careful with the front driveshaft and you will be good to go.
