What do you do when you have no onboard air?
I currently have a small onboard air pump (Viair), however I'm possibly going to sell it to buy something more useful for everyday life (fogs).
How often do those of you who do not have air have issues when this situation arises:
You hit the trail, nearest gas station is 20 miles away (mostly hwy), you only go with 1 or 2 Jeeps and they don't have air either. What then? Drive to the gas station on 14 psi?
I started off by airing down to 20 psi. Then I dropped it to 15 psi. All of this was before I had a compressor.
Either way, I drove slowly and cautiously back to the nearest gas station and refilled there.
Newtybar - you're local and we wheel the same trails - do you really want to be limited to trails that have a gas station nearby? We hit some trails where the nearest gas station could be 40+ miles...and I would not want to drive that distance on aired down tires all the time. It's just not good for them.
If you're going to wheel on a regular basis on these trails, IMO having at least a $50 Costco compressor is a necessity. Personally I'd consider it more important than fog lights, but that depends on how much wheeling you do.
I just got the 59 dollar one from Smittybuilt today. I have been off roading for a long time, but not until I got my JK, had I aired down. Mostly because I had done most of my off roading at work and that was the way I was trained and what I was used to. We did not have the equipment to air down, either. Plus, we were on and off road all day, so it was not practical (not to mention none of the wheeling was too heavy duty.)
To avoid having to drive on underpressured tires on the freeway, I decided that an air compressor was going to be my next purchase.
The little Smitty has a one year warranty, so hopefully, it is made sturdy enough.
Guys, I think if he's debating selling his compressor to get fog lights, a Power Plant isn't in his plans.
