FT 3" Alignment Issues
Old Apr 30, 2007 | 04:34 PM
rubiman's Avatar
Default FT 3" Alignment Issues
Anyone have there Jeep pull to either side after the lift? Got it aligned at Les Schwab and am still having issues - pulling to the right
3" FT
35" BFG Mud Terrains
Old Apr 30, 2007 | 04:37 PM
Rubimon's Avatar
Which kit did you use? Did you ket an adjustable track bar? Using the track bar bracket? Need more info.
Old Apr 30, 2007 | 04:40 PM
rubiman's Avatar
Got the Premium Kit....
Old Apr 30, 2007 | 04:43 PM
TEV's Avatar
TEV
who installed it? sound like maybe something isn't dialed in correctly. Is it actually pulling or is your steering wheel off?
Old Apr 30, 2007 | 06:20 PM
rubiman's Avatar
It is pulling to the right...
Old Apr 30, 2007 | 07:27 PM
wayoflife's Avatar
JK-Forum Founder
Okay, assuming that what you are experiencing isn't just the crown of the road pulling you over as is common on most streets, have you physically checked to see if your front axle is in fact centered under your Jeep? I know you said that you got your Jeep aligned but yours wouldn't be the first time I've heard of a shop doing a shoddy job. Need I say, if your track bar is still off a bit, this could cause a slight pull.
Old Apr 30, 2007 | 07:59 PM
Rubimon's Avatar
There are really any adjustments on the premium kit though, are there??? Aren't all trackbars and arms fixed?
Old Apr 30, 2007 | 08:06 PM
dhoffroad's Avatar
yea the arms with the premium are fixed, but I think the track bar is still adjustable...
not sure what to offer you as for advise except I know my local Less Schwab has a hard time getting alignment's done right the first time, second time....
