Stock suspension with winch
Has anyone installed a winch with the stock set-up? Jeep service told me that a winch and winch bumper will add 180 lbs to the front end. This will cause 'plowing' under normal braking and it will completely change the handling dynamics. They recommend new shocks at the very least. Its hard to imagine a jeep can't handle this additional weight.
Using a bumper designed for a winch will not void the warranty unless they determine it was abuse. There may come a time when you need to do more then 'mild winching'.
The question is 'can the stock suspension handle the weight'?
There are people here way more experienced then me. Start a new thread.
My gut tells me it would be a mistake to mount a winch on the stock bumper. I'm sure someone could fabricate something.
This was not my topic.
I installed 2 inch lift to front only and put on the LOD bumper and T Max 10000 winch... My front end went down over half an inch... Weight is noticeable... Its a 4 door X and the springs are not as stout as rubicons... Good luck and have fun with it!!!!!!!!!
yes. Warn makes winch plates that you bolt to the frame, not the bumper. Your winch doesnt rely on the bumper to hold it on. SO this way u can keep the stock bumper and have a winch
I Just Installed A Mopar Winch Bumper And I Will Be Installing A Winch Soon. I Have A 4 Door X Model, I Picked Up Some Rubicon Springs On Ebay, Will These Be Enough For The Added Wieght Of The Bumper And Winch?
