Shrockrails install questions?
For those of you that have installed the Schrockworks rock rails I have a few questions
The middle leg on the rails is more than a 1/4 inch from the frame, does it just get pulled in when you install the bolt.
The driver side rear leg is a 1/2" from the bottom of the frame, does this get pulled up?
One other question, when I have the bolts on the bottom,it is not level across, it seems to be close by the front wheel and farther away at the rear of the rail and I have the bottom bolts tight, am I going to have to shim it some way? I want to make sure I have it right before I start drilling.
thanks
thanks
Hey dsp, On the driver side, I unbolted the cross member from the frame rail and sandwiched my center slider mount inbetween the two. This allowed the rails to sit level and brought everything closer together including the gap you have. Whatever is remaining will get pulled in with the bolts. I'll try to post my write-up on it tomorrow if you still need it.
Here's a pic to show you what I did...
I installed them on my Unlimited and didn't have any problems like you are talking about. Everything lined up and then snugged up. Both sides match from front to rear. I bolted everything up tight and then made my marks before drilling. Used a center punch to make sure the bit didn't walk. It was a little more work but they went on nice.
Hey guys thanks for the tips. Wayoflife, I will try and do that on the drivers side and that might just do the trick. I was also thinking of having the rails go between the gas tank skid and the frame on the passenger side to make it work. Unfortunately I ran out of light.
If you can post the write up I would appreciate it , I was looking all over the forum for it. I think in March you said you were going to post it tommorow.....
You must be pretty busy.
Also do you think I can just put it between the frame and gas tank skid? I left a message at Shrockworks asking the same thing.
Other than this they look very good, the wife is very happy
Shrockworks Jeep JK Wrangler 4-Door Unlimited Rock Sliders Installation Write-Up
Let me know if you have any questions.
