Walker Evens Bead locks valve steams
Old Feb 24, 2009 | 09:26 PM
Lo2aY's Avatar
Default Walker Evens Bead locks valve steams
Anyone having a problem accessing their valve steams? I'm having a hard time getting to them to air up or down.
I thought about those bent valve steams but if I were to go that route, I would have to take off the TPMS sensors
Anyone have a solution for this issue?
Thanks
Old Feb 25, 2009 | 10:50 AM
Lo2aY's Avatar
I'm sure someone has those and fixed this issue
Wayoflife? anyone else?
Would it possibly relate to backspacing?
Bump
Old Feb 25, 2009 | 11:02 AM
STUPIDFACE's Avatar
im far from an expert, but couldnt you get some type of extension. not to leave on there all the time, just when you air up and down? by the way, the black walker evans
bl's look pretty bad ass....
corey d
Old Feb 25, 2009 | 01:37 PM
Lo2aY's Avatar
corey d
Hey Thanks
I was thinking about that. I need an angled extension. now I don't know if it screws on or if it pushes in! if it was to be screwed in. I wont be able todo so because I don't have room enough to go around and around!
Old Feb 25, 2009 | 08:33 PM
Lo2aY's Avatar
Originally Posted by putnam dan
I had a similar issue, you need a flexible extension like used to fill the inner tire on dual tire setups. it screws on but does fit as the end is small.
This difficulty translates to extra protection for your stems on the trail
Great Idea.. Thanks for your input
Would you possibly have pics of them? and if you don't mind me asking.. where did you get them from?
Thanks
