what about the performance accsesories body lift???
i have it too.....i have no complaints. its easy to install. it took me about 2 1/2 hrs to install. if i had to install another one, i could probably do it in less than an hour. you should note that the two back bolts are bigger than the rest of em. i farted around scratching my head and ass trying to figure out why the back bolts wouldnt thread in. i realized they were bigger and it went smooth after that. the washers are kind of a bitch to get off the original bolts too. despite these two issues, i would still recommend it. cheap and easy...
corey d
corey d
Seriously - how can you f'up a body lift? A 1" spacer is a 1" spacer. Unless they're made out of something biodegradable, why wouldn't any of them work? I got one for $99 and had it installed in under 2hrs with a floorjack and a section of 4x4 that I cut down to about a foot long to reach the body and lift it off the frame. Its uber easy.
$100 or LESS for an INCH of lift ... who wouldn't do that?
