16" wheels on a Rubicon?
Old Feb 26, 2009 | 03:25 PM
Rubi 2sday's Avatar
Default 16" wheels on a Rubicon?
I just got a 2008 Rubicon Unlimited, is there an issue with putting 16" alloys on it? I thought that I read someone had some brake caliper issues with 16's. I also noticed in some Mopar lift literature not to run anythong below 17". Then today I tried to order some pro comp 16's and the dealer called back stating that pro comp did not recomend 16's on the Rubicon, but were not specific as to why. What's the story?
Kevin
Old Feb 26, 2009 | 03:27 PM
w squared's Avatar
I think they may be trying to lead you down the garden path leading to more expensive wheels and tires.
AFAIK, there is no difference between a Rubi and an X that would prevent 16 inch wheels working just fine on a Rubi.
I have a friend that runs 16" steelies on his Rubi.
Many folks have had issues with 15's rubbing on the outside of their calipers...seems to be dependant on backspacing, but I'm not sure about that.
I can't recall anyone having issues with 16's, but I may be wrong on that.
Old Feb 26, 2009 | 03:32 PM
Piginajeep's Avatar
16's will work fine
Old Feb 26, 2009 | 03:38 PM
Thantos's Avatar
a couple people have had trouble with 16's on there rubi fronts. But is few and far between, you should be just fine
Old Feb 26, 2009 | 03:41 PM
Piginajeep's Avatar
theres no way this is correct
Rubicon and X models are the same thing. both the D44 and D30 use the same outters on the axle.
Old Feb 26, 2009 | 04:44 PM
rvator's Avatar
I have 16 inch pro comps with 4.5 inch backspacing on my X. I have plenty of clearence around the calipers. Got them from tirepackage.com
Old Feb 26, 2009 | 04:47 PM
Thantos's Avatar
Rubicon and X models are the same thing. oth the D44 and D30 use the same outters on the axle.
All I can do is say what I've read. Take it however you would like.
Stuka's Avatar
16's come stock on most X's out there. And the D44 in a rubicon is the same as a D30 from the tubes out. The shafts have a different spline count on the dif side. Just dont get wheels with tons of back spacing.
Old Feb 26, 2009 | 04:49 PM
JKJosh's Avatar
I've got a solution to your problem. Get some 18's and join the 18 inch wheel club. We are few and far between, but proud.
Old Feb 26, 2009 | 04:53 PM
slacktide's Avatar
You can run 15's on it. Just have to grind a little off the front caliber.
