JK Off-Road 101 Bulletin board forum regarding topics such as general off-roading tips, tricks, techniques and equipment usage such as winching and vehicle recovery information.
Sponsored by:
Sponsored by: CARiD
Submerged Winching?
Old Feb 27, 2009 | 02:36 PM
john smack's Avatar
Default Submerged Winching?
So I have always wondered, and now that I am in the market for a winch, what happens if you submerge your winch and you need to use it? will it work for a short distance? Like maybe just getting your tires up on the ruts of a deeole instead of down in them where the winch may get submerged?
Is there a winch out there that would peform better and last longer underwater?
Old Feb 27, 2009 | 04:49 PM
SiliconTi's Avatar
Well, I used mine submerged to pull out a Jeep (I, on the other hand was stuck for a couple days, long story). It worked just fine. Once I recovered my truck, I pulled it apart to dry/clean/grease it and it still works well today (this was a couple years ago).
Old Feb 27, 2009 | 06:01 PM
sgmrock's Avatar
X2 but I never pulled mine apart, been workin' 15 years now, it is a Warn.
Old Feb 28, 2009 | 05:12 AM
jkkat's Avatar
Most all the new winchs have water/weather proof relays so its not a huge deal but you do need to make sure that your greases/oils are ok.
note to self, check winch
Old Mar 3, 2009 | 10:37 AM
robin's Avatar
agree
Old Mar 3, 2009 | 11:05 AM
RedneckJeep's Avatar
Originally Posted by sgmrock
..............it is a Warn.
'Nuff said.
Old Mar 3, 2009 | 11:20 AM
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
I've never used my winch under water, heck never even though about having to, not that it hasnt been thru a little water
My warn is having some issues, I cant turn it to free spool, guess I have to see if I can get it covered by warranty. Anyone have any experience with warn warranty? Will really suck having to take it off and ship it.
Old Mar 3, 2009 | 07:39 PM
Dano9969's Avatar
What model Warn do you have?
Old Mar 4, 2009 | 01:57 PM
tkob1060's Avatar
Warn XD9000i
Old Mar 6, 2009 | 04:45 AM
TEEJ's Avatar
Talking
When you say you can't turn it to free spool...do you mean the lever won't move, or, after you shift it, its still engaged/not free spooling?
The lever's are reversible, and, its possible its just loose enough inside to jam. etc.
You can probably just take it apart/reassemble it, and be OK. Unless you have a baked fish in it or something...then you also have to remove the fish, etc.
