What 17" wheels with 37" tires?
I've got a black 09 Unlimited. I originally planned to put black wheels on, but I'm not a big fan of them. I've decided to go with allow and briefly looked at the AEV wheels, but they're a little more than I wanted to spend.
What are some other options? I know were somewhat limited.
pro comp has a good selection of wheels at good prices. However most of them are on backorder due to aluminum shortage in china. March madness is coming up for 4wd.com and 4 wheel parts so you should be able to get a good deal on some wheels and tires.
If I choose to get the AEV wheels what should I go with? I want 17" wheels with 37" tires.
Do I need the 17x8.5 5x5 Wide or 17x8.5 5x5?
AEV Pintler Beadlock TJ 5x4.5 JK 5x5 WK/XK 5x5
(-15mm offset*) (+10mm offset*) (+25mm offset*)
17x8.5 Argent $299 Buy Now Buy Now Buy Now
17x8.5 Silver $299 Buy Now Buy Now Buy Now
17inch AEV Pintler Wheels (Non-Beadlock) AEV Pintler TJ 5x4.5 JK 5x5 JK 5x5 WIDE WK/XK 5x5
(-15mm offset*) (+10mm offset*) (-15mm offset*) (+25mm offset*)
17x8.5 Argent $199 Buy Now Buy Now Buy Now Buy Now
17x8.5 Silver $199 Buy Now Buy Now Buy Now Buy Now
16inch AEV Bridger Wheels AEV Bridger TJ 5x4.5 JK 5x5 KJ/XJ/ZJ/MJ/YJ 5x4.5
(+6mm offset*) (+9mm offset*) (+6mm offset*)
16x8 Argent $179 Buy Now Buy Now Buy Now
16x8 Silver $179 Buy Now Buy Now Buy Now
16x8 Chrome $249 Buy Now Buy Now Buy Now
well to start you need the 5x5 bolt pattern. Their beadlocks I believe are not allowed onroad. But not certain on that. I like their Pintlers because they are a wide stance wheel which makes your tire stick out a little more. They cost a little more though.
Not sure on the offset but I believe they only make one size for our vehicles in the 17"
17x8.5 Size
5x5 Bolt Pattern
4.7" Backspacing
Here is a link of quadratec, you just have to decide on the color
http://quadratec.com/products/92500_10X_PG.htm
17x8.5 Size
5x5 Bolt Pattern
4.7" Backspacing
